| | | Forums66 Topics128,111 Posts1,056,243 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I could go on and on about making sure that wire is still grounding the case but you have spark at the plugs. It's just a backup to the case touching ground I guess, anyway do the gas down the carb test in my post and report results. Don't know what the compressor has to do with this but disconnect it electrically until you figure out starting problem. Did not see any info on the web for Petronix with a wire for ground. If it won't fire after gas down carb test, take that wire off once. And as stated DOUBLE CHECK TDC, etc. If an engine has timed spark and gas, it starts or trys to start.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | |
Entire Thread
electrical conundrum...get ready, it's a doozy
| starsfan | 10/16/2012 3:38 PM |
Re: electrical conundrum...get ready, it's a doozy
| Grigg | 10/16/2012 4:15 PM |
| Flxible | 10/16/2012 4:21 PM |
| starsfan | 10/16/2012 4:33 PM |
| Flxible | 10/16/2012 5:18 PM |
| starsfan | 10/16/2012 5:40 PM |
| FriedGreenTmater | 10/16/2012 5:51 PM |
| bartamos | 10/16/2012 6:39 PM |
| DrewP | 10/16/2012 6:44 PM |
| LGriffin | 10/16/2012 7:49 PM |
| starsfan | 10/16/2012 9:24 PM |
| starsfan | 10/16/2012 10:09 PM |
| Cletis | 10/16/2012 10:44 PM |
| starsfan | 10/16/2012 10:49 PM |
| Roy Rodgers | 10/16/2012 11:06 PM |
| starsfan | 10/16/2012 11:09 PM |
| bartamos | 10/16/2012 11:16 PM |
| GWWirth | 10/16/2012 11:21 PM |
| starsfan | 10/16/2012 11:27 PM |
| Flxible | 10/16/2012 11:30 PM |
| bartamos | 10/16/2012 11:32 PM |
| hippy | 10/17/2012 12:40 AM |
| Hotrod Lincoln | 10/17/2012 9:48 AM |
| starsfan | 10/17/2012 9:59 AM |
| bartamos | 10/17/2012 10:56 AM |
| Flxible | 10/17/2012 11:03 AM |
| bartamos | 10/17/2012 11:08 AM |
| starsfan | 10/17/2012 11:20 AM |
| bartamos | 10/17/2012 6:01 PM |
| Donsz | 10/18/2012 7:56 AM |
| starsfan | 10/18/2012 9:46 AM |
| Hotrod Lincoln | 10/18/2012 10:40 AM |
| Grigg | 10/18/2012 10:15 AM |
| starsfan | 10/18/2012 10:39 AM |
| bartamos | 10/18/2012 12:38 PM | |
