3 members (Bucker, 3B, Snowman51),
94
0
Mod | | | Forums66 Topics128,157 Posts1,056,893 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Your on the right track. Some folks turn the leaf springs around which will supposedly put the spring center pin close to where you want it.
I used my old rear end and went with a later pumpkin.
....on my 37 I did just what you mentined. I made a plate with holes to fit over the center bolt and then drilled another for the "offset". I have not had any problems and I "stand on it" quite often!
Just remember, meaure twice, cut once. | | |
