| | | Forums66 Topics128,010 Posts1,055,305 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Take off the fuel pump and work it by hand...does it sound like it is working? Your local Napa should have a fuel pump for cheap. That might fix your problem.
starting simple...is the valve under the tank open?
Does gas run from the tank to the pump when gas is installed in the tank? If yes...then is pump.... | | |
