9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.),
145
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80709 08/03/2007 12:30 AM | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | I replaced the core in mine but don't remember what it cost, wasn't to bad I don't think. I also added a pressure cap when it was redone. I only use a 3 lb cap but it works ok and doesn't spit coolant if it gets hot. If you are going to up grade motors, I would check in to a aluminum radiator. It will cost more up front, but it will cool anything you put behind it! Joe | | |
