8 members (Peggy M, klhansen, Wayne67vert, Otto Skorzeny, gswbbc, J Lucas, Tronman, 1 invisible), 117 guests, and 4 robots.
Topics128,042
Posts1,055,497
Members48,424
#80707 08/01/2007 3:49 AM
ANY ADVISE ON GETTING OLD RADIATOR REBUILT OR BUY A NEW ONE ? RECOMMEND SOURCE FOR NEW.I'M STILL RUNNING A 216.IF SOMEONE HAS A GOOD SOLID ONE I'D POSSIBLY CONSIDER THAT.IM IN SACRAMENTO CA.
It's not the speed you travel it's the quality of the trip that matters !!!
#80708 08/01/2007 4:07 AM
7 years ago I paid $235, or $265, to get a brand new core using my original tanks top and bottom. Since I'm running a V8 I had the old neck cut out and a later one put in so I could run a pressure cap(4lb)
So, depends on your future intentions. I'd take it to a reputable shop and get a diagnosis as to condition for repair or replace core.
#80709 08/03/2007 12:30 AM
I replaced the core in mine but don't remember what it cost, wasn't to bad I don't think. I also added a pressure cap when it was redone. I only use a 3 lb cap but it works ok and doesn't spit coolant if it gets hot. If you are going to up grade motors, I would check in to a aluminum radiator. It will cost more up front, but it will cool anything you put behind it! Joe
#80710 08/03/2007 2:20 AM
Apprentice
Apprentice
Sir,
I had the stock rad on my 1942 truck cleaned out, a few seeps soldered, and a 4 psi cap put. I hooked it up to a fresh rebuilt 261 and thought that my temperature gauge was not working - it did not get up to 100 degrees in 20 minutes of idling. I expected 'issues' with the restricted water flow induced by mounting the old waterpump low in the block ( compared to the 261 motor) - but had none.
They really don't make them like they used to!
Stewart
