| | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Les, I did look and I ended up calling them. The "20 mini" fuse block has 4 "slots" on the back of it that you stick a flat blade screw driver through..... and a couple other "tabs" to get it apart. Its cheap cheap cheap. I called the technician as I did not want to destroy a $182 investment. After we chatted a minute and I got the skinny on it he remarked, and I quote "I hear it everyday". Now ain't that some BS. If they get regular calls about it why not a simple slip of paper or notation on the kit/instructions. I guess that is TO easy! And as we said before they probably don't care. I had called and talked to these folks a couple weeks before ordering to ask where the wire was made and assembled. They "assured" me the wire and assembly was in America so I ordered it.
No BIG deal but its a cheap set up that could be fixed so simply. Anther Bolter tried to help but his must have been a different part # | | |
