| | | Forums66 Topics128,274 Posts1,058,425 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#74471 03/09/2007 12:44 AM | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Thanks Guys, the comments give me something more to think about, more further info is: the bypass oil filter was not on the truck as I needed the oil lines, the starter question: the old '58 has a foot pedal application starter the bendix engages first then the starter spins, no starter binding, I used a couple of bolts in the harmonic balancer and a bf* bar to try to turn over both directions-no dice- there isn't a ft crank bolt as is a press fit. camshaft should have oil as when I used drill to drive oil pump shaft the pathway for the oil is: pan,pump,main brgs,cam brgs,lifters,pushrods,rockers. and had oil at all rockers before distibutor install,valvecover and start. The conrod/piston pin siezing I didn't think of, also didn't try to remove fuelpump to see if pushrod/pump siezed. Hopefully will get the 1954 235 that is a runner advertised locally this weekend as a spare if my original suffered catastrophic failure. My main problem is stupidity on storing outside undercover and waiting to long to try to turn it over--Machine shop went out of business--Wunder why? :mad: | | | |
Entire Thread
235 6 cyl, ran 3 min, siezed
| 1958GMCnut | 03/08/2007 7:03 AM |
Re: 235 6 cyl, ran 3 min, siezed
| 3B | 03/08/2007 7:19 AM |
| 1958GMCnut | 03/08/2007 8:09 AM |
| meansam | 03/08/2007 12:40 PM |
| Grigg | 03/08/2007 12:43 PM |
| Fla54Chevy3100 | 03/08/2007 2:56 PM |
| 64fleetside | 03/08/2007 3:34 PM |
| atomarc | 03/08/2007 9:35 PM |
| 64fleetside | 03/08/2007 9:42 PM |
| Grigg | 03/08/2007 9:49 PM |
| 1958GMCnut | 03/09/2007 12:44 AM |
| Leo | 03/09/2007 2:35 AM |
| 48bigtrucks | 03/09/2007 3:36 AM |
| down2sea | 03/09/2007 3:45 AM |
| rasman57 | 03/09/2007 4:03 AM |
| 32fire2 | 03/09/2007 11:51 AM |
| meansam | 03/11/2007 1:09 PM |
| WE b OLD | 03/11/2007 8:11 PM |
| project 39 | 03/11/2007 10:04 PM |
| 1958GMCnut | 03/18/2007 3:11 PM |
| Darin367 | 03/18/2007 3:46 PM |
| RAC1812 | 03/19/2007 4:54 PM |
| Stovebold | 03/22/2007 12:01 AM |
| Hot Rod Dad | 03/22/2007 2:46 AM |
| Hot Rod Dad | 03/22/2007 2:48 AM |
| chiphead | 03/22/2007 4:40 AM |
| 1958GMCnut | 03/22/2007 8:12 AM |
| 1958GMCnut | 03/22/2007 8:14 AM |
| wick37 | 03/22/2007 1:45 PM |
| 1958GMCnut | 05/28/2007 8:28 AM |
| Roy Rodgers | 05/28/2007 12:50 PM |
| Fla54Chevy3100 | 05/28/2007 2:04 PM |
| Hotrod Lincoln | 05/28/2007 4:37 PM |
| Grigg | 05/28/2007 4:47 PM |
| 1958GMCnut | 06/02/2007 5:44 AM |
| SW_Radial | 06/02/2007 5:59 AM |
| 1958GMCnut | 06/04/2007 4:17 AM |
| 1958GMCnut | 06/05/2007 5:21 AM | |
