0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64517 08/19/2006 4:37 PM | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | It sounds like what you have is a muncie trans (55-65 non syncro first gear) with a Borg warner R10H OD unit. The OD unit is the same length as the long tail housing standard trans. All the internal gears are the same and connect to the OD mainshaft. If you have to replace the case you will need to drill a hole for the shift rail. Also you will have to reposition the rear end of the countershaft to fit the OD housing. If the OD trans was not previously installed in your 62 you may have to shorten the driveshaft as the 62 probably had a short tail housing. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
