| | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If it fell out it may be the wrong bushing. Unfortunately the best way to do it right is remove the clutch and pressure plate and start over. Make sure you have the right bushing, check the fit over the tranny shaft and also in the crank hole. Too tight and it won't go together and too loose you will ruin something later and it will squeal like a stuck pig. | | |
