| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | This new guy needs some help please.
Yesterday I tried to mount my transmission into my '54 Chevy 3100 and as I was doing it the Pilot bushing fell out of the crank. It is now sitting loosely between the clutch plat and pressure plate, which is mounted onto the truck.
Any advise on how I get the bushing back into the engine without having to pull the engine or disassemble the clutch? I really want to avoid all that. is it best to line it up and somehow tap it back in or should I remove the pressure plate to get at it.
Thanks in advance for any ideas...hopefully this has happened to someone before and I am not alone on this one.
Carlos | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If it fell out it may be the wrong bushing. Unfortunately the best way to do it right is remove the clutch and pressure plate and start over. Make sure you have the right bushing, check the fit over the tranny shaft and also in the crank hole. Too tight and it won't go together and too loose you will ruin something later and it will squeal like a stuck pig. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | it should be a press fit into the crank. you have to remove the pressure plate. it is only 6 bolts, I cannot see what obstacle that could be ron | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks for all the suggestions. It turns out I was able to use a 6" socket extension to grab the bushing and slot it back into place. I am just happy I didn't have to remove anything major, this project has been a fun little beast! | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | if it fell out before and you managed to put it back in with that extension; what is going to stop it from falling out again. they should be a press fit in there ron | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I'd take it to a parts store and find a better fitting piece. | | |
