Take the battery to a shop that uses a digital tester. It will be much more accurate than a load tester. The cheap load testers now a days only will only pull an average of 200 amps max. If the battery is rated at 750 cranking amps, and only puts out 350 it may pass the load test, but still won't do it's job.
