Are you asking how to get it out or what to do when you get it out.
If you can do an o-haul yourself & it doesn't need boreing or crank shaft ground then a minor o-haul kit will fix it up. If it needs complete rebuild or if you are not up to doing the laor yourself then a Goodwrench crate engine is the best bet. If the trans is working good & the fluid is not burnt then a seal job would be ok. If not then an o-haul is in order.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
