2 members (2-Ton, Jon G),
152
2
Mod | | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#45799 06/12/2005 8:47 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | In my 1960 manual, the 261 is described a a full pressure filter and the manual says to not plug the block where the oil filter lines normally go or you will get no oil circulation. My 235 in contrast is a "by-pass" filter and those holes can be plugged, the filter is basically an accessory. Maybe this is my ignorance speaking, but that tells me that the circulation of oil in the block differs between the two motors. Hopefully, someone more knowledgeable will chime in and explain the difference. | | | |
Entire Thread
261, Fenton Headers, and the oil lines....
| SWEET | 06/02/2005 9:03 PM |
Re: 261, Fenton Headers, and the oil lines....
| 53moneypit | 06/02/2005 10:21 PM |
| tclederman | 06/02/2005 10:42 PM |
| SWEET | 06/02/2005 10:51 PM |
| tclederman | 06/02/2005 11:12 PM |
| SWEET | 06/04/2005 1:45 PM |
| tclederman | 06/04/2005 3:13 PM |
| bigmacdaddy | 06/05/2005 12:54 AM |
| 49 geezer | 06/09/2005 10:10 PM |
| SWEET | 06/11/2005 2:11 PM |
| 6cylindersovertexas | 06/11/2005 7:21 PM |
| tclederman | 06/11/2005 9:01 PM |
| bigmacdaddy | 06/12/2005 8:47 AM |
| KENC | 06/12/2005 9:28 PM |
| KENC | 06/12/2005 9:49 PM |
| 6cylindersovertexas | 06/13/2005 5:34 AM |
| jackson | 07/19/2005 3:14 AM |
| NM51 | 09/22/2005 6:29 PM |
| NM51 | 09/23/2005 9:30 PM |
| Racecarl | 09/26/2005 3:05 AM |
| NM51 | 09/26/2005 6:26 PM |
| NM51 | 09/26/2005 7:15 PM | |
