In my opinion, for what it's worth, the brakes shouldn't cause the engine to over heat. That kind of drag shouldn't be any worse than pulling a trailer or hauling a load. I would look for a plugged radiator and or a head/head gasket problem. A proper diagnoses should be done instead of just hanging parts and hoping for the best.
If the brakes have just recently been done, my money is on being adjusted too tight. When I do brakes, I go for a drive afterwards with a brake adjusting tool on board. If I feel them starting to drag and smell like a burnt clutch, I pull over and back them off until they don't drag.
Without being there to see it first hand, this is just an educated guess on my part,
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
