If the brake shoes are stuck to the drums some drastic action may be required??....after all else fails.
I had one do that and I hooked a chain to the vehicle and started pulling it with my other truck. The wheel slide for about 10 feet then popped loose and started turning. I also had a friend walk beside it and give it a good whack in the center of the wheel. Once it broke loose the drum came off easy.
May not be a very nice way but it worked and no damage was done.
