| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've always called them "freeze plugs" and the ones I have seen the "dome" actually goes to the inside. When you can get to them you just pop one edge of it with a punch or something to flip it sideways and then hook a screwdriver in it and pop it out.
Like red58 says, Replace them all and don't knock it inside the block and leave it. I have seen this done on hard to reach plugs and its a no no. I replace one long ago and stuck my finger down inside the block and pulled out 2 more that were rusted so you can imagine what they do the water cirulation! Some will be rusted out right in the middle and some leak on the edge. Clean the rim where the plug goes and use just a "tat" of sealer and your good to go. | | |
