I hope this works. Here are some photos that I up loaded. I have many more but lets see if others can veiw this first. Well on the front fenders we found some old steel patches that are brazed in. I will be ordering new lower fender repair patches. I am amazed at how many different styles of mirros have been on this truck. I have 19 holes in one door and 18 in the other!!!. The doors both have been hit in the same place. The dents are at the front,top of the door panel.???? Nothing that my new maga spot gun cant handle. Looking forward to testing it out this evening. There are plenty of dents to work on LOL. better than rust.
I am using upol self etching filler primer. The cool thing about this product is that if you reduce it to a certain level it is a easy sanding filler primer. Now reduce it down more it becomes a sealer that needs not top coat. So areas like the insides of fenders, cab floor, etc you can spray it once and forget about it. Works great and saves money in the process. One thing I did find is that you need a large gun to shoot it though. I am priming with a 1.8 gun and it is spraying find and lays down great, even if you are only shooting a light cover coat to stop any rust. Like the outer door skins I shot it extremely light as we will be working with it soon. It levels out great no pebbles, or rocks.
[IMG]http://thumb9.webshots.net/t/68/168/1/4/41/2090104410102714229vDLRte_th.jpg[/IMG]
