1 members (Gdads51),
100
2
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | I finally got around to measuring my pins that I believe to be original. They measure 343 thousandths (if i remember correctly) but the equivilent is 11/64th. I couldn't believe my own figuring so like a big dummy I ran a 3/8 bit through one of my hinge pieces,rather than a piece of scrap, and it is TOO BIG. I finally dug arond and found a 11/64 bit and drilled them out "straight" on my drill press and they seem to be fine. I figure the "oversize" ones may be a 3/8th...or at least that is what I'm hoping as I will probably never find another hinge and my 52 panel did not have any bushings. (guess I could use some!!) I checked the size where they are knurled under the head and what keeps them from "working out" and the measurement is .005 bigger there. This still doesn't answer the question of just what size it the repop's!! Maybe someone else has the other half of the question?! I might add here that if anyones "pins" are even the slightest bent they will be contrary to get in and work properly. | | |
