I don't think the pressure plate is "indexed" to your flywheel on your application. You will need to align the disc to the flywheel though. You should still have your clutch centering arbor from your clutch kit, that should be all you need. If it is indexed, it will only go on one way so you can't really screw anything up anyway,
Scott
