Muggs
Go to picapart and get a shroud.......Fit it and fill the daylight seams with spray foam from Homeless depot
You can also use the foam to fill inside the shroud if you thing it's too hollow
Start the engine only after it sets up!!!!!!
The fan will clearence itself MAKE SURE THE AIR CLEANER IS TIGHT AND MASK OFF THE FRONT SO THE FOAM DOESN'T MUSS IT
