Anyone tried an auxiliary radiator cooler such as those avaible from JC Whitney and what not?
My '54 tends to run a little warm when climbing hills and also after driving a bit on the freeway, when I exit, temp climbs with the decrease in airflow across the front.
It's got a new radiator, brass, non stock so the old shroud no longer fits. Installed an 18" metal flex fan which has helped and one of these days I'll get around to making a shroud. Just wondering if an aux. cooler may help keep temps more consistent. Or maybe aux. cooler in conjunction with electric fan.
-David
