Topics128,188
Posts1,057,218
Members48,465
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
Finally, formed and connected all brake lines! The little bits and pieces that you think you have but don't can be frustrating and slow you down. I set aside an hour here or there only to be foiled because I didn't have the right fitting(s). Anyways, 3/16" hard steel lines to the front discs, 1/4" NiCop lines to the rear drums. Residual valves in place for front and rear, all connections tied into proportioning valve and new, dual master cylinder. Next step is to connect the master cylinder rod to the brake arm, and since the new master cylinder is bigger and mounted to the frame where OEM m/c was, I need to offset the linkage about 1". My plan is to weld in a thick bushing to the brake arm, run a 3/8" Grade 8 bolt thru that and clamp down. See the last picture of that set up and if any brake gurus think it won't work, please tell me now! After that, I will take m/c off, bench bleed, reattach, bleed all 4 corners and, barring any leaks, can wrap the brake system up. After that, I think I can mount the cab back onto the frame before shoulder surgery takes me out of action for 6 months... Halfway there!
Entire Thread
1953 GMC 3/4-ton, deluxe cab, long bed -- "My Biggest Project"
mvigo 07/13/2025 4:01 AM
Re: 1953 GMC 3/4-ton, deluxe cab, long bed -- "My Biggest Project"
mvigo 07/13/2025 4:09 AM
Otto Skorzeny 07/13/2025 4:20 AM
mvigo 07/13/2025 2:15 PM
J Lucas 07/13/2025 4:22 AM
Phak1 07/13/2025 12:35 PM
mvigo 07/13/2025 2:16 PM
UtahYork 07/13/2025 5:43 PM
mvigo 07/23/2025 2:31 AM
Otto Skorzeny 07/23/2025 4:09 AM
mvigo 07/23/2025 4:20 AM
Otto Skorzeny 07/23/2025 4:30 AM
Paul Mullen 07/23/2025 11:17 AM
mvigo 07/23/2025 3:14 PM
mvigo 07/26/2025 6:35 PM
TUTS 59 07/27/2025 2:42 PM
mvigo 07/27/2025 3:42 PM
TUTS 59 07/27/2025 4:02 PM
mvigo 07/27/2025 9:51 PM
mvigo 08/02/2025 1:58 PM
UtahYork 08/02/2025 3:04 PM
mvigo 08/02/2025 5:38 PM
Otto Skorzeny 08/02/2025 4:24 PM
mvigo 08/02/2025 5:20 PM
mvigo 08/02/2025 5:35 PM
Phak1 08/02/2025 5:58 PM
Otto Skorzeny 08/02/2025 6:12 PM
Otto Skorzeny 08/02/2025 6:16 PM
mvigo 08/02/2025 9:16 PM
mvigo 08/04/2025 3:36 AM
KevinS 08/04/2025 4:34 PM
mvigo 08/23/2025 11:24 PM
Bill Hanlon 08/24/2025 12:17 AM
mvigo 08/27/2025 3:16 AM
mvigo 09/13/2025 2:42 AM
Gdads51 09/13/2025 2:51 AM
mvigo 09/13/2025 3:47 AM
Gdads51 09/13/2025 11:42 AM
mvigo 09/13/2025 3:25 PM
mvigo 09/18/2025 2:29 AM
Otto Skorzeny 09/18/2025 2:49 AM
mvigo 09/18/2025 2:56 AM
Wayne67vert 09/18/2025 12:26 PM
Gdads51 09/18/2025 1:36 PM
Paul Mullen 09/19/2025 12:46 PM
mvigo 02/04/2026 5:12 PM
Gdads51 02/05/2026 1:22 AM
mvigo 02/14/2026 4:08 PM
mvigo 03/02/2026 4:24 AM
Otto Skorzeny 03/02/2026 2:18 PM
Phak1 03/03/2026 2:16 PM
mvigo 03/26/2026 12:35 AM
J Lucas 03/26/2026 3:41 AM
Gdads51 03/26/2026 1:35 PM
mvigo 03/26/2026 3:28 PM
Gdads51 03/26/2026 4:15 PM
mvigo 03/26/2026 4:41 PM
klhansen 03/26/2026 4:47 PM
mvigo 03/26/2026 5:22 PM
Phak1 04/16/2026 1:27 PM
mvigo 04/17/2026 2:29 PM
