| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | I believe the change in distributor gear material coincided with the switch from steel to cast iron cams at the same time the cam bearing diameter also changed. That would have been in 1954 or so. The steel cams with the small diameter bearings were used in the 216s and spray-oiler 235s. Jerry
