8 members (Donf, 57 Drifter, baldeagle, HandyAndy, gswbbc, tclederman, Cosmo, 1 invisible),
122
2
Mod | | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | does anyone know of a way to make an add on tip that will spot weld for my Lincoln 135 mig welder? I tried to locate this item from lincoln, but had no luck. I made a copper tube with vees cut in each side and it worked half way decent, but would value others input. I plan to use it to weld in my replacement floorboards. Thanks in advance.
ChuckB
'50 Chevy 1/2 ton 3100
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
