| | | Forums66 Topics128,193 Posts1,057,363 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | does anyone know of a way to make an add on tip that will spot weld for my Lincoln 135 mig welder? I tried to locate this item from lincoln, but had no luck. I made a copper tube with vees cut in each side and it worked half way decent, but would value others input. I plan to use it to weld in my replacement floorboards. Thanks in advance.
ChuckB
'50 Chevy 1/2 ton 3100
Chuck
1950 Chevy 3100 Deluxe Cab A few Harleys and '76 Triumph Bonneville
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | doorguru,
In my limited knowledge, I will say a true spot weld is a resistance weld...something that can't be duplicated with your wire feed unit.
What you can do is make plug welds that work great, and when ground down a tad could be passed off as a spot weld.
Maybe you are confusing the two processes. Won't all this be covered with paint, carpet and undercoat anyway?
Stuart | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Doorguru I know what you are looking for it is the notched tip for your mig any welding supplier should carry them and they are pretty cheap. http://www.justoffbase.co.uk/s.nl;jsessionid=ac112b1d1f43d271786d7e814e7da916acc202afe2f1.e3iKaNePch4Re34LchyPa3iPa3v0n6jAmljGr5XDqQLvpAe?sc=9&category=752&it=A&id=5172 | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | doorguru, I have enclosed a link that might be of interest. This device needs to be powered by a stick welder, so you might be out of luck if you only have the MIG setup. If you try it, give us some feedback on how it performs! http://www.eastwoodco.com/jump.jsp?itemID=1227&itemType=PRODUCT Stuart | | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | Thanks everyone for the info.. That's exactly what I was looking for.. I will check my local supplier.. Is this a great forum or what ?? : )
ChuckB
Chuck
| | | | | Joined: Apr 2010 Posts: 123 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 123 | Originally posted by atomarc: doorguru,
Stuart Stuart.. that's pretty nifty.. I am thinking about going for it.. I wonder if I will work horizontally ?? ChuckB
Chuck
Its looks like it uses a carbon arc rod..a gouging rod, so it doesn't have filler material to drip and run. I would say this is a all position device.
The carbon rod will heat the parent metal up and sort of melt/fuse the two pieces together. If it does work, I'll bet it's pretty nifty indeed.
Remember, gotta have a stick welder to use it!
Stuart | | |
