I'll bet that the three pins with lock nuts didn't get positioned correctly. They engage a collar that holds the front pinion bearing forward. If the collar isn't fully forward on installation, the pins won't be able to keep the pinion from moving backward. The attached figure is for an AD differential, but I'd bet the '46 would be the same.
Kevin
1951 Chevy 3100 work truck
Photos
