| | | Forums66 Topics128,186 Posts1,057,324 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Bztguy,
Offset = distance from the mounting surface of the wheel to the centerline of the wheel. Farther outboard is (+) offset, inboard is (-) offset. Centerline directly over mounting surface is (0) offset.
Backspace = distance from inboard edge of the rim to the mounting surface of the wheel. Otto: To clarify, Positive offset moves the mounting surface outboard relative to the centerline and will move the wheel centerline inboard and vise versa. See Les Schwab website for illustration. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | |
Entire Thread
Camber, Toe in/out, and caster on a stock 3600
| bztguy | 07/29/2024 2:00 AM |
Re: Camber, Toe in/out, and caster on a stock 3600
| Otto Skorzeny | 07/29/2024 2:41 AM |
| klhansen | 07/29/2024 3:00 AM |
| 1Ton_tommy | 07/29/2024 4:12 AM |
| bztguy | 07/29/2024 1:32 PM |
| Otto Skorzeny | 07/29/2024 7:03 PM |
| Jon G | 07/29/2024 10:13 PM |
| Jon G | 07/29/2024 10:58 PM |
| 52Carl | 07/30/2024 1:22 AM |
| bztguy | 07/30/2024 1:40 AM |
| Otto Skorzeny | 07/30/2024 1:54 AM |
| Otto Skorzeny | 07/30/2024 2:22 AM |
| Jon G | 07/30/2024 3:22 AM |
| 1Ton_tommy | 07/30/2024 7:48 PM |
| Otto Skorzeny | 07/30/2024 8:11 PM |
| 1Ton_tommy | 08/03/2024 3:07 PM |
| Otto Skorzeny | 07/30/2024 8:26 PM |
| bztguy | 07/31/2024 2:27 PM |
| Jon G | 07/31/2024 4:41 PM |
| Otto Skorzeny | 07/31/2024 10:26 PM |
| bztguy | 08/02/2024 2:43 AM | |
