0 members (),
102
3
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Otto you asked,
Does the steering wheel return to center normally when driving on smooth roads? Not really. I have to steer it back. Will it track straight if you let go of the wheel? Yes, on a smooth straight road. Is it easy to steer? It steers easily enough once you get moving
1Ton_Tommy They are not the original rims. I'll have to check since I put them on years ago but I believe they were 8" which may be contributing to my problem? Also when setting toe in toe out at what point is that being measured? Across the front edge of the tires? Geometrically the distance you make the measurement in relation away from the centerline of the spindle all comes into play since we are forming a triangle.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
Entire Thread
Camber, Toe in/out, and caster on a stock 3600
| bztguy | 07/29/2024 2:00 AM |
Re: Camber, Toe in/out, and caster on a stock 3600
| Otto Skorzeny | 07/29/2024 2:41 AM |
| klhansen | 07/29/2024 3:00 AM |
| 1Ton_tommy | 07/29/2024 4:12 AM |
| bztguy | 07/29/2024 1:32 PM |
| Otto Skorzeny | 07/29/2024 7:03 PM |
| Jon G | 07/29/2024 10:13 PM |
| Jon G | 07/29/2024 10:58 PM |
| 52Carl | 07/30/2024 1:22 AM |
| bztguy | 07/30/2024 1:40 AM |
| Otto Skorzeny | 07/30/2024 1:54 AM |
| Otto Skorzeny | 07/30/2024 2:22 AM |
| Jon G | 07/30/2024 3:22 AM |
| 1Ton_tommy | 07/30/2024 7:48 PM |
| Otto Skorzeny | 07/30/2024 8:11 PM |
| 1Ton_tommy | 08/03/2024 3:07 PM |
| Otto Skorzeny | 07/30/2024 8:26 PM |
| bztguy | 07/31/2024 2:27 PM |
| Jon G | 07/31/2024 4:41 PM |
| Otto Skorzeny | 07/31/2024 10:26 PM |
| bztguy | 08/02/2024 2:43 AM | |
