7 members (69 coupe, Gdads51, Phak1, jmoore, TUTS 59, 54farmtruck, 1955 1 Series),
91
2
Mod | | | Forums66 Topics128,188 Posts1,057,329 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I've been reading searching through the threads on this subject. My 49' 3600 is completely stock for steering and suspension. I'm running 16" rims with radials. My problem is on a good smooth and flat road it drives and tracks great. But hit some bumps or dips and it wants to wander like heck. It also tends to not want to pull out of sharper curves. I have all new leaf springs shackle bolts/bushings, tie rod ends and kingpins. I also have replaced all lever shocks with gas tube and added a sway bar. I've also adjusted the steering box per factory procedures. At this point I think the front end is about as up tp snuff as I can make it. The outer edge of the tires are wearing prematurely. When I eyeball it from the front the camber looks excessive. The tires are very obviously leaning outwards at the top. I'm contemplating taking it to a heavy truck shop in case the axle needs bending for camber. What I'm not sure of is what would be the best camber, toe in or toe out and caster setting the shop should shoot for? Aligning a 49' 3/4 ton truck is not something they've probably ran into before.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
Entire Thread
Camber, Toe in/out, and caster on a stock 3600
| bztguy | 07/29/2024 2:00 AM |
Re: Camber, Toe in/out, and caster on a stock 3600
| Otto Skorzeny | 07/29/2024 2:41 AM |
| klhansen | 07/29/2024 3:00 AM |
| 1Ton_tommy | 07/29/2024 4:12 AM |
| bztguy | 07/29/2024 1:32 PM |
| Otto Skorzeny | 07/29/2024 7:03 PM |
| Jon G | 07/29/2024 10:13 PM |
| Jon G | 07/29/2024 10:58 PM |
| 52Carl | 07/30/2024 1:22 AM |
| bztguy | 07/30/2024 1:40 AM |
| Otto Skorzeny | 07/30/2024 1:54 AM |
| Otto Skorzeny | 07/30/2024 2:22 AM |
| Jon G | 07/30/2024 3:22 AM |
| 1Ton_tommy | 07/30/2024 7:48 PM |
| Otto Skorzeny | 07/30/2024 8:11 PM |
| 1Ton_tommy | 08/03/2024 3:07 PM |
| Otto Skorzeny | 07/30/2024 8:26 PM |
| bztguy | 07/31/2024 2:27 PM |
| Jon G | 07/31/2024 4:41 PM |
| Otto Skorzeny | 07/31/2024 10:26 PM |
| bztguy | 08/02/2024 2:43 AM | |
