There is a tool designed to help with compression of the spring so you can remove that pin. It is called Herbrand no. 188. Search ebay and there will be several for sale. Makes quick work of removing and replacing that pin without losing the spring.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
