3 members (Donf, cmayna, 1 invisible),
172
Mod | | | Forums66 Topics128,288 Posts1,058,569 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Starting well, even with a cold engine, can be a indication of good cylinder compression (piston rings to cylinder wall contact). For example, an engine with worn rings can be harder to start.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | |
Entire Thread
Timed with Vac, now won't start
| Goach2 | 05/06/2022 1:55 PM |
Re: Timed with Vac, now won't start
| JW51 | 05/06/2022 2:18 PM |
| Jon G | 05/06/2022 2:20 PM |
| Joe H | 05/06/2022 3:11 PM |
| Goach2 | 05/06/2022 3:25 PM |
| Hotrod Lincoln | 05/06/2022 11:38 PM |
| Truckrolet | 05/16/2022 12:14 AM |
| Goach2 | 05/09/2022 5:03 PM |
| JW51 | 05/09/2022 8:19 PM |
| Dragsix | 05/09/2022 6:22 PM |
| 52Carl | 05/09/2022 6:28 PM |
| Goach2 | 05/09/2022 6:55 PM |
| Bill Hanlon | 05/11/2022 2:57 AM |
| JW51 | 05/09/2022 8:16 PM |
| Hotrod Lincoln | 05/10/2022 3:49 AM |
| Goach2 | 05/10/2022 1:22 PM |
| Hotrod Lincoln | 05/10/2022 5:42 PM |
| Hotrod Lincoln | 05/11/2022 3:18 AM |
| Bill Hanlon | 05/13/2022 8:35 PM |
| Goach2 | 05/11/2022 1:59 PM |
| Goach2 | 05/12/2022 2:29 PM |
| Goach2 | 05/12/2022 3:32 PM |
| Goach2 | 05/12/2022 7:04 PM |
| JW51 | 05/13/2022 10:38 AM |
| 52Carl | 05/13/2022 12:19 AM |
| Goach2 | 05/13/2022 12:40 PM |
| Dragsix | 05/13/2022 12:42 PM |
| Goach2 | 05/13/2022 1:55 PM |
| Dragsix | 05/13/2022 6:23 PM |
| Goach2 | 05/13/2022 7:00 PM |
| JW51 | 05/13/2022 8:14 PM |
| Goach2 | 05/14/2022 11:33 PM |
| 52Carl | 05/16/2022 12:25 AM |
| Goach2 | 05/15/2022 1:38 PM |
| JW51 | 05/15/2022 2:15 PM |
| Goach2 | 05/15/2022 2:44 PM |
| JW51 | 05/15/2022 3:10 PM |
| Goach2 | 05/16/2022 1:13 PM |
| JW51 | 05/16/2022 2:09 PM |
| Goach2 | 05/16/2022 6:26 PM |
| JW51 | 05/16/2022 6:53 PM |
| Goach2 | 05/16/2022 7:02 PM |
| JW51 | 05/16/2022 7:35 PM |
| Justhorsenround | 05/16/2022 7:14 PM |
| Goach2 | 05/16/2022 11:25 PM |
| Goach2 | 05/17/2022 12:14 AM |
| 52Carl | 05/17/2022 12:59 AM |
| Goach2 | 05/17/2022 2:38 PM |
| Goach2 | 05/18/2022 9:44 PM |
| JW51 | 05/18/2022 9:54 PM |
| Goach2 | 05/18/2022 11:10 PM |
| JW51 | 05/19/2022 12:31 AM |
| Hotrod Lincoln | 05/19/2022 4:51 PM |
| Goach2 | 05/19/2022 9:57 PM |
| Hotrod Lincoln | 05/19/2022 10:49 PM |
| Goach2 | 05/20/2022 12:57 AM |
| Hotrod Lincoln | 05/20/2022 1:18 AM |
| Goach2 | 05/20/2022 12:14 PM |
| JW51 | 05/20/2022 12:30 PM |
| Goach2 | 05/20/2022 12:45 PM |
| JW51 | 05/20/2022 1:29 PM |
| Hotrod Lincoln | 05/20/2022 1:34 PM |
| Goach2 | 05/20/2022 10:03 PM |
| JW51 | 05/20/2022 10:36 PM |
| Goach2 | 05/20/2022 10:45 PM |
| JW51 | 05/20/2022 10:56 PM |
| Goach2 | 05/21/2022 5:31 PM |
| Hotrod Lincoln | 05/21/2022 6:10 PM |
| Goach2 | 05/21/2022 6:14 PM |
| Gord&Fran | 05/21/2022 6:53 PM |
| buoymaker | 05/21/2022 7:10 PM |
| buoymaker | 05/21/2022 7:18 PM |
| Hotrod Lincoln | 05/21/2022 7:41 PM |
| buoymaker | 05/21/2022 8:35 PM |
| Goach2 | 05/21/2022 8:56 PM |
| Hotrod Lincoln | 05/21/2022 9:43 PM |
| Goach2 | 05/22/2022 12:25 AM |
| Hotrod Lincoln | 05/22/2022 1:12 AM |
| buoymaker | 05/22/2022 1:32 AM |
| Hotrod Lincoln | 05/22/2022 2:11 AM |
| Goach2 | 05/23/2022 12:45 PM |
| Justhorsenround | 05/23/2022 1:29 PM |
| buoymaker | 05/23/2022 3:29 PM | |
