3 members (Donf, cmayna, 1 invisible),
172
Mod | | | Forums66 Topics128,288 Posts1,058,569 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Go it. Thanks Jerry. So I take it that the rotation of the pushrods MAY be a source of concern but it's not the cause of the original problem. I would think the engine needs to run, varying speeds, on the road (loading the engine), for an extended period of time (circulate the oil). What I'm trying to say is that maybe the lifters lost their pre-load of oil if the valve adjustment was too tight. Hopefully they will recover as the engine runs in the future. If they don't, there is information on Stovebolt on how to manually pre-load. I would only do the pre-load NOW if a lifter sounds like it is going to self-destruct. My 2 pennies.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | | |
Entire Thread
Timed with Vac, now won't start
| Goach2 | 05/06/2022 1:55 PM |
Re: Timed with Vac, now won't start
| JW51 | 05/06/2022 2:18 PM |
| Jon G | 05/06/2022 2:20 PM |
| Joe H | 05/06/2022 3:11 PM |
| Goach2 | 05/06/2022 3:25 PM |
| Hotrod Lincoln | 05/06/2022 11:38 PM |
| Truckrolet | 05/16/2022 12:14 AM |
| Goach2 | 05/09/2022 5:03 PM |
| JW51 | 05/09/2022 8:19 PM |
| Dragsix | 05/09/2022 6:22 PM |
| 52Carl | 05/09/2022 6:28 PM |
| Goach2 | 05/09/2022 6:55 PM |
| Bill Hanlon | 05/11/2022 2:57 AM |
| JW51 | 05/09/2022 8:16 PM |
| Hotrod Lincoln | 05/10/2022 3:49 AM |
| Goach2 | 05/10/2022 1:22 PM |
| Hotrod Lincoln | 05/10/2022 5:42 PM |
| Hotrod Lincoln | 05/11/2022 3:18 AM |
| Bill Hanlon | 05/13/2022 8:35 PM |
| Goach2 | 05/11/2022 1:59 PM |
| Goach2 | 05/12/2022 2:29 PM |
| Goach2 | 05/12/2022 3:32 PM |
| Goach2 | 05/12/2022 7:04 PM |
| JW51 | 05/13/2022 10:38 AM |
| 52Carl | 05/13/2022 12:19 AM |
| Goach2 | 05/13/2022 12:40 PM |
| Dragsix | 05/13/2022 12:42 PM |
| Goach2 | 05/13/2022 1:55 PM |
| Dragsix | 05/13/2022 6:23 PM |
| Goach2 | 05/13/2022 7:00 PM |
| JW51 | 05/13/2022 8:14 PM |
| Goach2 | 05/14/2022 11:33 PM |
| 52Carl | 05/16/2022 12:25 AM |
| Goach2 | 05/15/2022 1:38 PM |
| JW51 | 05/15/2022 2:15 PM |
| Goach2 | 05/15/2022 2:44 PM |
| JW51 | 05/15/2022 3:10 PM |
| Goach2 | 05/16/2022 1:13 PM |
| JW51 | 05/16/2022 2:09 PM |
| Goach2 | 05/16/2022 6:26 PM |
| JW51 | 05/16/2022 6:53 PM |
| Goach2 | 05/16/2022 7:02 PM |
| JW51 | 05/16/2022 7:35 PM |
| Justhorsenround | 05/16/2022 7:14 PM |
| Goach2 | 05/16/2022 11:25 PM |
| Goach2 | 05/17/2022 12:14 AM |
| 52Carl | 05/17/2022 12:59 AM |
| Goach2 | 05/17/2022 2:38 PM |
| Goach2 | 05/18/2022 9:44 PM |
| JW51 | 05/18/2022 9:54 PM |
| Goach2 | 05/18/2022 11:10 PM |
| JW51 | 05/19/2022 12:31 AM |
| Hotrod Lincoln | 05/19/2022 4:51 PM |
| Goach2 | 05/19/2022 9:57 PM |
| Hotrod Lincoln | 05/19/2022 10:49 PM |
| Goach2 | 05/20/2022 12:57 AM |
| Hotrod Lincoln | 05/20/2022 1:18 AM |
| Goach2 | 05/20/2022 12:14 PM |
| JW51 | 05/20/2022 12:30 PM |
| Goach2 | 05/20/2022 12:45 PM |
| JW51 | 05/20/2022 1:29 PM |
| Hotrod Lincoln | 05/20/2022 1:34 PM |
| Goach2 | 05/20/2022 10:03 PM |
| JW51 | 05/20/2022 10:36 PM |
| Goach2 | 05/20/2022 10:45 PM |
| JW51 | 05/20/2022 10:56 PM |
| Goach2 | 05/21/2022 5:31 PM |
| Hotrod Lincoln | 05/21/2022 6:10 PM |
| Goach2 | 05/21/2022 6:14 PM |
| Gord&Fran | 05/21/2022 6:53 PM |
| buoymaker | 05/21/2022 7:10 PM |
| buoymaker | 05/21/2022 7:18 PM |
| Hotrod Lincoln | 05/21/2022 7:41 PM |
| buoymaker | 05/21/2022 8:35 PM |
| Goach2 | 05/21/2022 8:56 PM |
| Hotrod Lincoln | 05/21/2022 9:43 PM |
| Goach2 | 05/22/2022 12:25 AM |
| Hotrod Lincoln | 05/22/2022 1:12 AM |
| buoymaker | 05/22/2022 1:32 AM |
| Hotrod Lincoln | 05/22/2022 2:11 AM |
| Goach2 | 05/23/2022 12:45 PM |
| Justhorsenround | 05/23/2022 1:29 PM |
| buoymaker | 05/23/2022 3:29 PM | |
