3 members (Donf, cmayna, 1 invisible),
172
Mod | | | Forums66 Topics128,288 Posts1,058,569 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,692 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,692 | Clarification - I meant the pushrods should rotate as the engine is running, not you rotati g them by hand.
That is what you are talking about, right?
All pushrods should rotate at a pace you can easily see at idle. If some are not, I would pull those and roll on an extremely flat surface…a big piece of glass or your wife’s granite countertop. A wobble indicates a bent pushrod.
1951 3100
Entire Thread
Timed with Vac, now won't start
| Goach2 | 05/06/2022 1:55 PM |
Re: Timed with Vac, now won't start
| JW51 | 05/06/2022 2:18 PM |
| Jon G | 05/06/2022 2:20 PM |
| Joe H | 05/06/2022 3:11 PM |
| Goach2 | 05/06/2022 3:25 PM |
| Hotrod Lincoln | 05/06/2022 11:38 PM |
| Truckrolet | 05/16/2022 12:14 AM |
| Goach2 | 05/09/2022 5:03 PM |
| JW51 | 05/09/2022 8:19 PM |
| Dragsix | 05/09/2022 6:22 PM |
| 52Carl | 05/09/2022 6:28 PM |
| Goach2 | 05/09/2022 6:55 PM |
| Bill Hanlon | 05/11/2022 2:57 AM |
| JW51 | 05/09/2022 8:16 PM |
| Hotrod Lincoln | 05/10/2022 3:49 AM |
| Goach2 | 05/10/2022 1:22 PM |
| Hotrod Lincoln | 05/10/2022 5:42 PM |
| Hotrod Lincoln | 05/11/2022 3:18 AM |
| Bill Hanlon | 05/13/2022 8:35 PM |
| Goach2 | 05/11/2022 1:59 PM |
| Goach2 | 05/12/2022 2:29 PM |
| Goach2 | 05/12/2022 3:32 PM |
| Goach2 | 05/12/2022 7:04 PM |
| JW51 | 05/13/2022 10:38 AM |
| 52Carl | 05/13/2022 12:19 AM |
| Goach2 | 05/13/2022 12:40 PM |
| Dragsix | 05/13/2022 12:42 PM |
| Goach2 | 05/13/2022 1:55 PM |
| Dragsix | 05/13/2022 6:23 PM |
| Goach2 | 05/13/2022 7:00 PM |
| JW51 | 05/13/2022 8:14 PM |
| Goach2 | 05/14/2022 11:33 PM |
| 52Carl | 05/16/2022 12:25 AM |
| Goach2 | 05/15/2022 1:38 PM |
| JW51 | 05/15/2022 2:15 PM |
| Goach2 | 05/15/2022 2:44 PM |
| JW51 | 05/15/2022 3:10 PM |
| Goach2 | 05/16/2022 1:13 PM |
| JW51 | 05/16/2022 2:09 PM |
| Goach2 | 05/16/2022 6:26 PM |
| JW51 | 05/16/2022 6:53 PM |
| Goach2 | 05/16/2022 7:02 PM |
| JW51 | 05/16/2022 7:35 PM |
| Justhorsenround | 05/16/2022 7:14 PM |
| Goach2 | 05/16/2022 11:25 PM |
| Goach2 | 05/17/2022 12:14 AM |
| 52Carl | 05/17/2022 12:59 AM |
| Goach2 | 05/17/2022 2:38 PM |
| Goach2 | 05/18/2022 9:44 PM |
| JW51 | 05/18/2022 9:54 PM |
| Goach2 | 05/18/2022 11:10 PM |
| JW51 | 05/19/2022 12:31 AM |
| Hotrod Lincoln | 05/19/2022 4:51 PM |
| Goach2 | 05/19/2022 9:57 PM |
| Hotrod Lincoln | 05/19/2022 10:49 PM |
| Goach2 | 05/20/2022 12:57 AM |
| Hotrod Lincoln | 05/20/2022 1:18 AM |
| Goach2 | 05/20/2022 12:14 PM |
| JW51 | 05/20/2022 12:30 PM |
| Goach2 | 05/20/2022 12:45 PM |
| JW51 | 05/20/2022 1:29 PM |
| Hotrod Lincoln | 05/20/2022 1:34 PM |
| Goach2 | 05/20/2022 10:03 PM |
| JW51 | 05/20/2022 10:36 PM |
| Goach2 | 05/20/2022 10:45 PM |
| JW51 | 05/20/2022 10:56 PM |
| Goach2 | 05/21/2022 5:31 PM |
| Hotrod Lincoln | 05/21/2022 6:10 PM |
| Goach2 | 05/21/2022 6:14 PM |
| Gord&Fran | 05/21/2022 6:53 PM |
| buoymaker | 05/21/2022 7:10 PM |
| buoymaker | 05/21/2022 7:18 PM |
| Hotrod Lincoln | 05/21/2022 7:41 PM |
| buoymaker | 05/21/2022 8:35 PM |
| Goach2 | 05/21/2022 8:56 PM |
| Hotrod Lincoln | 05/21/2022 9:43 PM |
| Goach2 | 05/22/2022 12:25 AM |
| Hotrod Lincoln | 05/22/2022 1:12 AM |
| buoymaker | 05/22/2022 1:32 AM |
| Hotrod Lincoln | 05/22/2022 2:11 AM |
| Goach2 | 05/23/2022 12:45 PM |
| Justhorsenround | 05/23/2022 1:29 PM |
| buoymaker | 05/23/2022 3:29 PM | |
