| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | One degree of movement of the distributor changes the ignition timing at the crankshaft two degrees, since the crank turns twice as fast as the distributor. It doesn't take much adjustment at the octane selector to make a big difference at the flywheel. Also, one degree of ignition timing over-advance once the best torque point under load is reached robs as much power as 5 degrees of retarded timing from the ideal setting. I've proved that repeatedly on dyno runs. Over advance is trying to make the engine run backwards. ALWAYS err on the side of "not enough" timing advance. That's why monitoring vacuum at idle while changing timing makes no sense at all. Jerry
Entire Thread
Timed with Vac, now won't start
| Goach2 | 05/06/2022 1:55 PM |
Re: Timed with Vac, now won't start
| JW51 | 05/06/2022 2:18 PM |
| Jon G | 05/06/2022 2:20 PM |
| Joe H | 05/06/2022 3:11 PM |
| Goach2 | 05/06/2022 3:25 PM |
| Hotrod Lincoln | 05/06/2022 11:38 PM |
| Truckrolet | 05/16/2022 12:14 AM |
| Goach2 | 05/09/2022 5:03 PM |
| JW51 | 05/09/2022 8:19 PM |
| Dragsix | 05/09/2022 6:22 PM |
| 52Carl | 05/09/2022 6:28 PM |
| Goach2 | 05/09/2022 6:55 PM |
| Bill Hanlon | 05/11/2022 2:57 AM |
| JW51 | 05/09/2022 8:16 PM |
| Hotrod Lincoln | 05/10/2022 3:49 AM |
| Goach2 | 05/10/2022 1:22 PM |
| Hotrod Lincoln | 05/10/2022 5:42 PM |
| Hotrod Lincoln | 05/11/2022 3:18 AM |
| Bill Hanlon | 05/13/2022 8:35 PM |
| Goach2 | 05/11/2022 1:59 PM |
| Goach2 | 05/12/2022 2:29 PM |
| Goach2 | 05/12/2022 3:32 PM |
| Goach2 | 05/12/2022 7:04 PM |
| JW51 | 05/13/2022 10:38 AM |
| 52Carl | 05/13/2022 12:19 AM |
| Goach2 | 05/13/2022 12:40 PM |
| Dragsix | 05/13/2022 12:42 PM |
| Goach2 | 05/13/2022 1:55 PM |
| Dragsix | 05/13/2022 6:23 PM |
| Goach2 | 05/13/2022 7:00 PM |
| JW51 | 05/13/2022 8:14 PM |
| Goach2 | 05/14/2022 11:33 PM |
| 52Carl | 05/16/2022 12:25 AM |
| Goach2 | 05/15/2022 1:38 PM |
| JW51 | 05/15/2022 2:15 PM |
| Goach2 | 05/15/2022 2:44 PM |
| JW51 | 05/15/2022 3:10 PM |
| Goach2 | 05/16/2022 1:13 PM |
| JW51 | 05/16/2022 2:09 PM |
| Goach2 | 05/16/2022 6:26 PM |
| JW51 | 05/16/2022 6:53 PM |
| Goach2 | 05/16/2022 7:02 PM |
| JW51 | 05/16/2022 7:35 PM |
| Justhorsenround | 05/16/2022 7:14 PM |
| Goach2 | 05/16/2022 11:25 PM |
| Goach2 | 05/17/2022 12:14 AM |
| 52Carl | 05/17/2022 12:59 AM |
| Goach2 | 05/17/2022 2:38 PM |
| Goach2 | 05/18/2022 9:44 PM |
| JW51 | 05/18/2022 9:54 PM |
| Goach2 | 05/18/2022 11:10 PM |
| JW51 | 05/19/2022 12:31 AM |
| Hotrod Lincoln | 05/19/2022 4:51 PM |
| Goach2 | 05/19/2022 9:57 PM |
| Hotrod Lincoln | 05/19/2022 10:49 PM |
| Goach2 | 05/20/2022 12:57 AM |
| Hotrod Lincoln | 05/20/2022 1:18 AM |
| Goach2 | 05/20/2022 12:14 PM |
| JW51 | 05/20/2022 12:30 PM |
| Goach2 | 05/20/2022 12:45 PM |
| JW51 | 05/20/2022 1:29 PM |
| Hotrod Lincoln | 05/20/2022 1:34 PM |
| Goach2 | 05/20/2022 10:03 PM |
| JW51 | 05/20/2022 10:36 PM |
| Goach2 | 05/20/2022 10:45 PM |
| JW51 | 05/20/2022 10:56 PM |
| Goach2 | 05/21/2022 5:31 PM |
| Hotrod Lincoln | 05/21/2022 6:10 PM |
| Goach2 | 05/21/2022 6:14 PM |
| Gord&Fran | 05/21/2022 6:53 PM |
| buoymaker | 05/21/2022 7:10 PM |
| buoymaker | 05/21/2022 7:18 PM |
| Hotrod Lincoln | 05/21/2022 7:41 PM |
| buoymaker | 05/21/2022 8:35 PM |
| Goach2 | 05/21/2022 8:56 PM |
| Hotrod Lincoln | 05/21/2022 9:43 PM |
| Goach2 | 05/22/2022 12:25 AM |
| Hotrod Lincoln | 05/22/2022 1:12 AM |
| buoymaker | 05/22/2022 1:32 AM |
| Hotrod Lincoln | 05/22/2022 2:11 AM |
| Goach2 | 05/23/2022 12:45 PM |
| Justhorsenround | 05/23/2022 1:29 PM |
| buoymaker | 05/23/2022 3:29 PM | |
