3 members (Donf, cmayna, 1 invisible),
172
Mod | | | Forums66 Topics128,288 Posts1,058,569 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 728 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 728 | Can you believe points cost $25 now? What a joke. Waiting for them to come in to local FLAPS, then I will do the 'static' timing that Deve suggests. It looks like TDC is accurate on the flywheel, based on my previous pic, so that would make the ball 5 degrees advanced ('5' is labelled on flywheel beside it. I supposed I will shoot for that for now and then adjust the carb. I don't really get the 'advanced until it pings under load and then retard until it doesn't'. I was trying to get 'optimal', but I will settle for 'spec'  | | | |
Entire Thread
Timed with Vac, now won't start
| Goach2 | 05/06/2022 1:55 PM |
Re: Timed with Vac, now won't start
| JW51 | 05/06/2022 2:18 PM |
| Jon G | 05/06/2022 2:20 PM |
| Joe H | 05/06/2022 3:11 PM |
| Goach2 | 05/06/2022 3:25 PM |
| Hotrod Lincoln | 05/06/2022 11:38 PM |
| Truckrolet | 05/16/2022 12:14 AM |
| Goach2 | 05/09/2022 5:03 PM |
| JW51 | 05/09/2022 8:19 PM |
| Dragsix | 05/09/2022 6:22 PM |
| 52Carl | 05/09/2022 6:28 PM |
| Goach2 | 05/09/2022 6:55 PM |
| Bill Hanlon | 05/11/2022 2:57 AM |
| JW51 | 05/09/2022 8:16 PM |
| Hotrod Lincoln | 05/10/2022 3:49 AM |
| Goach2 | 05/10/2022 1:22 PM |
| Hotrod Lincoln | 05/10/2022 5:42 PM |
| Hotrod Lincoln | 05/11/2022 3:18 AM |
| Bill Hanlon | 05/13/2022 8:35 PM |
| Goach2 | 05/11/2022 1:59 PM |
| Goach2 | 05/12/2022 2:29 PM |
| Goach2 | 05/12/2022 3:32 PM |
| Goach2 | 05/12/2022 7:04 PM |
| JW51 | 05/13/2022 10:38 AM |
| 52Carl | 05/13/2022 12:19 AM |
| Goach2 | 05/13/2022 12:40 PM |
| Dragsix | 05/13/2022 12:42 PM |
| Goach2 | 05/13/2022 1:55 PM |
| Dragsix | 05/13/2022 6:23 PM |
| Goach2 | 05/13/2022 7:00 PM |
| JW51 | 05/13/2022 8:14 PM |
| Goach2 | 05/14/2022 11:33 PM |
| 52Carl | 05/16/2022 12:25 AM |
| Goach2 | 05/15/2022 1:38 PM |
| JW51 | 05/15/2022 2:15 PM |
| Goach2 | 05/15/2022 2:44 PM |
| JW51 | 05/15/2022 3:10 PM |
| Goach2 | 05/16/2022 1:13 PM |
| JW51 | 05/16/2022 2:09 PM |
| Goach2 | 05/16/2022 6:26 PM |
| JW51 | 05/16/2022 6:53 PM |
| Goach2 | 05/16/2022 7:02 PM |
| JW51 | 05/16/2022 7:35 PM |
| Justhorsenround | 05/16/2022 7:14 PM |
| Goach2 | 05/16/2022 11:25 PM |
| Goach2 | 05/17/2022 12:14 AM |
| 52Carl | 05/17/2022 12:59 AM |
| Goach2 | 05/17/2022 2:38 PM |
| Goach2 | 05/18/2022 9:44 PM |
| JW51 | 05/18/2022 9:54 PM |
| Goach2 | 05/18/2022 11:10 PM |
| JW51 | 05/19/2022 12:31 AM |
| Hotrod Lincoln | 05/19/2022 4:51 PM |
| Goach2 | 05/19/2022 9:57 PM |
| Hotrod Lincoln | 05/19/2022 10:49 PM |
| Goach2 | 05/20/2022 12:57 AM |
| Hotrod Lincoln | 05/20/2022 1:18 AM |
| Goach2 | 05/20/2022 12:14 PM |
| JW51 | 05/20/2022 12:30 PM |
| Goach2 | 05/20/2022 12:45 PM |
| JW51 | 05/20/2022 1:29 PM |
| Hotrod Lincoln | 05/20/2022 1:34 PM |
| Goach2 | 05/20/2022 10:03 PM |
| JW51 | 05/20/2022 10:36 PM |
| Goach2 | 05/20/2022 10:45 PM |
| JW51 | 05/20/2022 10:56 PM |
| Goach2 | 05/21/2022 5:31 PM |
| Hotrod Lincoln | 05/21/2022 6:10 PM |
| Goach2 | 05/21/2022 6:14 PM |
| Gord&Fran | 05/21/2022 6:53 PM |
| buoymaker | 05/21/2022 7:10 PM |
| buoymaker | 05/21/2022 7:18 PM |
| Hotrod Lincoln | 05/21/2022 7:41 PM |
| buoymaker | 05/21/2022 8:35 PM |
| Goach2 | 05/21/2022 8:56 PM |
| Hotrod Lincoln | 05/21/2022 9:43 PM |
| Goach2 | 05/22/2022 12:25 AM |
| Hotrod Lincoln | 05/22/2022 1:12 AM |
| buoymaker | 05/22/2022 1:32 AM |
| Hotrod Lincoln | 05/22/2022 2:11 AM |
| Goach2 | 05/23/2022 12:45 PM |
| Justhorsenround | 05/23/2022 1:29 PM |
| buoymaker | 05/23/2022 3:29 PM | |
