Just polish the spindle with a sanding pad to soften the edges and to clean the spindle. There are no pressures or vacuums to worry about. The seals just keep water and dust out. If deep grooves worry you, set the seals deeper or less deep in the hub so it doesn't ride in the same groove.
That's my advise,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
