| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Bolt on hub cap on the front designates it as a 2 ton or greater. 1.5 ton only have screwed on CI hub cap. Ton ratings are sort of vague, not very useful. 2 tons came with 5/10 lug bolts which you have. That front axle allows you to replace spindles and disc brake hubs out with later(90’s) P-30 and P3500HD spindles and hubs with the same bolt pattern wheels if you wish.
Ed
'37 GMC T-18 w/ DD 4-53T, RTO-610, 6231 aux., '95 GMC running gear, full disc brakes, power steering, 22.5 wheels and tires. '47 GMC 1 ton w/ 302, NP-540, 4wd, full width Blazer front axle. '54 GMC 630 w/ 503 gasser, 5 speed, ex fire truck, shortened WB 4', install 8' bed. '55 GMC 370 w/270, 420 4 speed, grain, dump bed truck from ND. Works OK.
Entire Thread
How many Tons -- 1, 1.5 or 2? (1952)
| sambo42xa | 02/10/2022 2:57 PM |
Re: How many Tons -- 1, 1.5 or 2? (1952)
| Joe H | 02/10/2022 3:08 PM |
| John L. | 02/10/2022 5:12 PM |
| J Lucas | 02/10/2022 6:19 PM |
| 78buckshot | 02/11/2022 12:34 AM |
| EdPruss | 02/11/2022 12:44 AM |
| Mike B | 02/11/2022 12:46 AM |
| sambo42xa | 02/11/2022 5:59 PM |
| Fox | 02/11/2022 6:34 PM |
| 69Cuda | 02/11/2022 9:01 PM |
| sambo42xa | 02/11/2022 9:33 PM |
| John Milliman | 02/12/2022 12:17 AM |
| 69Cuda | 02/14/2022 5:29 AM |
| Mike B | 02/12/2022 1:50 AM |
| klhansen | 02/15/2022 12:58 AM |
| John Milliman | 02/14/2022 10:58 AM |
| tclederman | 02/14/2022 1:02 PM |
| John Milliman | 02/15/2022 12:36 AM |
| tclederman | 02/15/2022 12:51 AM |
| John Milliman | 02/15/2022 1:18 AM |
| klhansen | 02/15/2022 1:27 AM |
| Mike B | 02/15/2022 3:06 AM |
| sambo42xa | 02/15/2022 10:53 PM |
| John Milliman | 02/15/2022 11:44 PM |
| fixite7 | 02/18/2022 11:51 AM |
| Chevy's till I d | 03/04/2022 2:55 PM |
| Chevy's till I d | 03/04/2022 3:14 PM |
| sambo42xa | 03/04/2022 7:43 PM |
| crenwelge | 03/06/2022 3:48 AM |
| tclederman | 03/06/2022 4:21 AM |
| sambo42xa | 03/06/2022 10:42 PM | |
