If someone has a Delco Remy Service Manual page for a 1937 Oldsmobile they could share? If, not maybe the attachment will be good enough.
This is what I read: Delco Remy 1100002 is similar to the 936-T. The 1100002 has higher output current ratings. Fixed third brush. External voltage regulated. Oldsmobile used the Delco Remy 5814 (4 terminal) voltage regulator to go with this generator. Generator terminal "A" to regulator terminal "Gen". Generator terminal "F" to regulator terminal "F". Regulator terminal "Ign." to ignition switch. Note: Olds. switch with at least 3 terminals. Regulator terminal "Bat." to ammeter "+"
In the older Chevrolet Master Parts List, the 1100002 is listed as getting a return credit towards a rebuilt generator.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
