| | | Forums66 Topics128,268 Posts1,058,191 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,721 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,721 | did it both ways, but yes doors off will be more comfortable for working in cab. Leave hinges on the door side. Drill small holes (guide holes) through the hinges into cab prior to removing. 1/16 bit or so. Then when reinstalling doors put the drill bit into hinge and through to cab as a guide. door should line up where it was previous to removal. There may be shims under the bolts (6 bolts) that help align the door in/out. Make note of where shims are prior to removing door. The shims will fall out when bolts are loosened. | | | |
Entire Thread
Remove the cab or not, 1950 Five Window
| ChevyDarren | 01/26/2021 12:13 AM |
Re: Remove the cab or not, 1950 Five Window
| Bill Trotter | 01/26/2021 12:28 AM |
| klhansen | 01/26/2021 2:42 AM |
| ChevyDarren | 01/26/2021 4:33 AM |
| Fox | 01/26/2021 6:09 AM |
| klhansen | 01/26/2021 6:53 AM |
| ChevyDarren | 01/26/2021 7:28 PM |
| Hambone | 01/26/2021 12:12 PM |
| MPandC | 01/26/2021 2:15 PM |
| archburycontrol | 01/26/2021 2:51 PM |
| klhansen | 01/26/2021 7:14 PM |
| KEVINSKI | 01/26/2021 7:30 PM |
| klhansen | 01/26/2021 7:57 PM |
| ChevyDarren | 01/27/2021 12:33 AM |
| TUTS 59 | 01/27/2021 1:24 PM |
| Fox | 01/27/2021 6:09 AM |
| Rocket man | 01/28/2021 5:09 AM |
| ChevyDarren | 02/01/2021 8:39 PM |
| Fox | 02/02/2021 6:21 AM |
| WarEagle1 | 02/03/2021 1:40 AM |
| ChevyDarren | 02/08/2021 4:35 PM |
| Hambone | 02/03/2021 12:44 PM |
| WarEagle1 | 02/03/2021 2:29 PM |
| Hambone | 02/03/2021 3:34 PM |
| WarEagle1 | 02/03/2021 5:02 PM |
| FinnBolt | 02/08/2021 2:29 PM |
| Fox | 02/10/2021 5:05 AM |
| Hambone | 02/10/2021 12:18 PM |
| WarEagle1 | 02/11/2021 4:06 PM | |
