Quote
u can use late model(2001 & similar ones) 2wd s10 blazer front spindles(they are a bolt on). these will push ur rims out about 1 to 1 1/2 inches
More info, please? Are you saying that the 2001 and newer S-10s have a wider front track than the older ones?
I'm about to rebuild the front end of my 89 S-10 frame for my AD conversion, and I'd sure like to make the front end wider if needed.
