| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | Aren't some of those front bushings riveted into the torque tube? I was thinking of the old banjo-housing Ford axle when I suggested pushing on the pinion gear. That pinion and bearing assembly disassembles by driving the pinion and double tapered roller bearing out the front of the housing! Jerry
