| | | Forums66 Topics128,188 Posts1,057,332 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Get a bigger hammer 3lb sledge! Hammer around the drum as if your were doing a 5 lug tire. More then likely it is rusted to the hub (this is rear). If it is the fronts see above.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | |
Entire Thread
Removing brake drums, help?
| LeftEar55 | 03/24/2005 12:52 PM |
Re: Removing brake drums, help?
| Wrenchbender Ret. | 03/24/2005 2:32 PM |
| dale937 | 03/24/2005 2:37 PM |
| Brian Moore | 03/24/2005 3:52 PM |
| Hotrod Lincoln | 03/24/2005 4:07 PM |
| LeftEar55 | 03/24/2005 11:28 PM |
| LAROKE | 03/24/2005 11:42 PM |
| Dad's 65 | 03/25/2005 1:45 AM |
| LeftEar55 | 03/25/2005 4:05 AM |
| Hotrod Lincoln | 03/25/2005 4:13 AM |
| 64fleetside | 03/25/2005 4:14 AM |
| HardyRestoration | 03/25/2005 4:26 AM |
| mugsy | 03/25/2005 4:46 AM |
| 48bigtrucks | 03/25/2005 5:12 AM |
| Fran and Gord | 03/25/2005 5:14 AM |
| InMy40s | 03/25/2005 5:29 AM |
| jgalt_54-235 | 03/25/2005 7:11 AM |
| Dan S | 03/25/2005 8:54 AM |
| Wrenchbender Ret. | 03/25/2005 10:22 PM |
| Wrenchbender Ret. | 03/25/2005 10:23 PM |
| GMCPauly | 03/26/2005 12:30 AM |
Anonymous
| 03/26/2005 2:08 AM |
| shooper | 03/26/2005 2:40 AM |
| 4d9r | 03/26/2005 5:14 AM | |
