| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I should add that the large circular grommet in the picture with the single wire is where the ammeter to coil wire goes. In an original truck the wire would have been in a metal conduit, so called "armored" as an anti-theft device. I believe GM called that Electro-Lok. There was a metal cap on the coil that covered the connection to the coil. Kent | | |
