5 members (jmoore, Bill Hanlon, 3B, 54farmtruck, Phak1), 95 guests, and 1 robot.
Topics128,188
Posts1,057,329
Members48,469
Need a picture or location of where oil line from engine to gauge goes through the fire wall. I don't see any holes where mine should have been. Thanks for any help. Bill
1937 GC
Bill,
Here is a photo of a '37 firewall (not mine), showing the 4 hole grommet and mounting bracket. The temperature gauge line, oil pressure line, throttle cable and choke cable go through the grommet. The bracket and hole in the firewall have an enlarged circular cutout that allows the temp bulb to go through.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
I should add that the large circular grommet in the picture with the single wire is where the ammeter to coil wire goes. In an original truck the wire would have been in a metal conduit, so called "armored" as an anti-theft device. I believe GM called that Electro-Lok. There was a metal cap on the coil that covered the connection to the coil.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Just what I needed Kent. Getting ready to install my dash. Thank you. Bill
1937 GC
