| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 43 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 43 | When I measured 36 volts coming off altenator trucks was at idle speed and battery was still connected normal and I used a volt meter with one lead to frame ground and other lead to the altenator post where hot wire connects to alternator. When I measured 10 volts between frame ground and negative battery post truck was turned off. I left positive cable still connected to battery and disconnected frame ground from battery . I got a volt meter connected one lead to negative post of battery and one lead to frame ground and measured 10 volts. Is all this normal ? | | |
