| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | Change the spark plugs, even if they're new. Once plugs get fuel-soaked, it's possible they can leak voltage away down the insulator when under compression pressure without jumping the gap. I've seen it happen several times. Jerry
