| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | TDC happens twice- - - -once on compression and again on overlap. Firing the plug at the valve overlap point results in a "no start" condition. Be SURE you have compression when the plug fires. Jerry
