First, GO FOR A DRIVE, while your out get couple of quarts of Diesel. Second when you get home, do as Jerry suggested. Drain the pan, go inside and have a cup of coffee. Come back out and PUT THE PLUG BACK IN. Fill with your choice of motor oil and call it good. DO NOT PULL THE PAN without new gaskets on hand.
Now go inside and fix the rocking toilet.
Fun day for sure!ðŸ‘ðŸ»
