| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | It sounds like you've got a corroded wheel cylinder on the wheel that's locking. The pistons probably can't retract fully, which is holding the shoes tight against the drum. Massage the drum a little with a dead blow mallet to drive the shoes back and slip the drum off to inspect the wheel cylinder. If it's stuck, I'd strongly consider replacing it rather than rebuilding. Good brakes are cheap life insurance- - - -for you, and the rest of us who share the road with you! Jerry
