FYI, only posting in the Greasy Spoon isn't getting your post count up to where you leave moderated status. You need four approved posts outside of the 'spoon to gain full site permissions. Posts in the 'spoon don't count. Every post you make in the 'spoon until you reach four is requiring a moderator to manually approve it. It would be beneficial to all if you make three more in other forums. We know you have knowledge to share that could help folks in the technical forums. You could probably teach the best of us a few tricks. I know I could use some help in the Short Bus forum at times. grin
